Trying to avoid flycutting...
measure twice, cut once. Flycutting isn't really that hard. Just take your time if you end up having to flycut.
Ideally you should pick out the heads and cam based on how much static compression (basically how many cc's your heads have) and dynamic compression (heavily influenced by the cam and gasket) and where you want the powerband to be. Try not to pick a combo just cause you might have to flycut a little.
