Pix of c2000ws6's engine bay w/relocated coils
Charlie just had his Heads and Cam installed recently and had Whistler (Targa Top Z28) paint his coils packs and relocate them
Instead of moving them to the firewall, Chris fabricated a couple of plates out of raw Carbon Fiber and mounted them directly onto the Fuel Rails
Here are a few pix I took at the FUEL **** meet last night:
Rick
Rick
Re: Pix of c2000ws6's engine bay w/relocated coils
TTT, would like to know where the relocation brackets can be had
My question is, will the stock length plug wires work? If so, I might try to fab some up at work sometime.
Administrator
I don't like the look of the coil packs right on the fuel rails. The idea behind relocating them is to create space and to provide easy acess to plugs, valve covers, etc. It's even more ugle than a stock LS1. Whatever happened to being subtle?
With all that said, the fab work looks great. It's just not my taste which doesn't amount to anything since it's not my ride.
What's the point? I guess if you change spark plugs or pull the valve covers off often, it would make the job easier. Don't get me wrong, it looks clean, but seems pointless. Do you really want the extra weight put on the fuel rails? Are there reinforcement bracket of some kind? Hey, if it works for you then that's all that counts!
