LS4 Performance - Oil Pressure sending unit
View Full Version : Oil Pressure sending unit
silverGXP
07-29-2007, 12:30 PM
Does anyone know where to put the oil pressure sending unit for the gauges at? Where is the spot on the engine? I am not sure.
Thank you
Kevin
Sint3k
07-29-2007, 06:10 PM
I thought it already had a oil pressure sending unit ? Maybe i'm not understanding you. As far as i know of you can split the connection off of the factory oil pressure sending unit to a gauge inside the cabin.
silverGXP
07-30-2007, 04:14 PM
Where is it located on the block? The sending unit?
Dfasdf45
07-30-2007, 07:57 PM
According to the 07 MC/Imp service manual, it's located on the Valve Lifter Oil Manifold located in the 'V'. Look beside the throtle body close to the intake manifold on the front or oil filter side of the engine.
Dfasdf45
Nacho SS
07-30-2007, 08:20 PM
Dfasdf45
Good to know... :judge:
silverGXP
07-30-2007, 10:15 PM
Is that where I would want to put the sending unit for the gauge?
Also any pic?
Nacho SS
07-31-2007, 12:35 AM
Are you going to put an oil gauge in the a pillar?
nighthand
07-31-2007, 06:20 AM
Interested as well because I want to do the same thing...
And yes, in the A pillar
Nacho SS
07-31-2007, 05:34 PM
Me too..... :) :) :lurk:
Dfasdf45
07-31-2007, 09:25 PM
Hmm, duno if you could replace the sender. This is where the sensor is for the oil pressure that the ECM uses.
There's also a replaceable oil filter up there for the Valvle Lifter Oil Manifold. It's right under the oil pressure sender, remove the sender and you can then remove the filter according to the service manual.
Interestingly, the service manual says that if you replace the Valvle Lifter Oil Manifold oil filter, that you should replace the o-ring and the oil pressure sender with new parts.
Dfasdf45
silverGXP
08-01-2007, 03:43 PM
Ya I want to put it in the piller, I just need to know where to put the sender on the block. Any more info or pic will be great. Has anyone done this yet?
NHRAMAN
08-01-2007, 03:51 PM
I need to know also----I think it is in the rear of engine,just below the manifold.... and a hassle.
Sint3k
08-01-2007, 03:54 PM
Anyone know about the trans temp gauge on the 06 mcss if you can just split the signal off into a gauge or what. Would be nice to have a pod with voltage / trans temp and oil pressure.
silverGXP
08-03-2007, 04:11 PM
So does no one know where to tap in at? Hmmmm
Sint3k
08-04-2007, 06:02 PM
If you find out silver please post i'm very interested. I do know one guy with a 06 impala SS who has a Trans Temp gauge using the stock sensor i'm trying to get ahold of him. Hes on cardomain the one with the Corvette flag V painted on his hood.
Corny40
08-05-2007, 01:11 AM
There's actually someone who painted that on their hood?!? How big? Post a link when you find it. Please. :)
