MAF Testing
MAF Testing
Can you still test a MAF by its idle voltage output like the older LT1's? I have a 02 that stutters a little bit at idle, its the last think I can think to check. I've checked the plugs, intake, wires and o2 sensors. Also, if someone could please give me a flow rate at idle. I have a scanner that will read active data.
Thanks
Thanks
