O2 Slow Response
Old 07-30-2007, 08:37 AM
A-Dub's Avatar
Default O2 Slow Response
Current setup on the car was completed in May. At that time, I installed a pair of new 13111s into the headers I just installed. Tuned the car and all was well. For the last 2 months, the car has basically been parked, although I did frequently move it in and out of the garage. Pulled it out to start driving it again last week and it sets the O2 slow response code for BOTH banks. The sensors have less than 500 miles on them. I cleared them and they came back on 50 miles later.
Did I damage the O2s by starting the car, backing it out of the garage, and turning it off? If thats not it, what would cause both sensors to throw the code at the same time like this?
Thanks
AW
Old 07-30-2007, 08:43 AM
AFASTYZFR1's Avatar
Did you get on it any? When my pcm resets from unplugging the battery that code stays in the not ran section on my predator and will set the ses if I dont do a wot pass.....I have the bosch sensors also and once I do a few good runs the code goes away and hasn't come back up
Old 07-30-2007, 10:12 AM
A-Dub's Avatar
Hmmmm, no I haven't romped on it at all. I will take it out for some spirited runs today and see what that does
Old 07-30-2007, 02:58 PM
Frost's Avatar
They most likely are set at idle since they will be switching like they should (enough heat) once you are moving much at all.
Old 07-31-2007, 05:44 PM
bww3588's Avatar
yesterday, after filling up my tank, i got P0153 (slow response bank 2 sensor 1). i put my rear stockers in the front. could they be going bad, or do i jsut need to do a WOT run when it sets the SES light?
Old 08-01-2007, 10:13 AM
A-Dub's Avatar
I cleared the codes and did some WOT throttle runs....the SES light hasn't come back, but my drive to work is about 4 miles, so it will probably take a few days for it to set again
Old 08-01-2007, 02:30 PM
bww3588's Avatar
ive heard the fix for this is the bosch 13111's but ive also heard that people having this problem with the 13111's.......so what is next?
Old 08-01-2007, 03:14 PM
A-Dub's Avatar
I have Bosch 13111s....
Old 08-01-2007, 05:22 PM
bww3588's Avatar
the only thing i could think of to permantly fix this would be widebands......
Old 08-04-2007, 09:40 AM
RE AND CHERYL's Avatar
Wide band sensors don't usually have the best life expectancy.
Old 08-05-2007, 11:02 PM
DrkPhx's Avatar
I had the same problem and couldn't figure it out, so I bought new GM sensors and ran a test. I installed one GM and one Bosch sensor, then datalogged the two during normal driving. Sure enough the Bosch sensor was switching noticeably slower compared to the GM sensor. The LTFT's on the Bosch side were also way off.
Old 08-05-2007, 11:08 PM
bww3588's Avatar
so the autozone bullshit might be the cause. just go to GM and bend over in front of the parts counter, point at your *** and tell them you want 2 O2's right there?
Old 08-05-2007, 11:16 PM
DrkPhx's Avatar
Possibly. Call SDPC (sponsor here) for the best prices on GM parts.
Old 08-05-2007, 11:56 PM
Frost's Avatar
I did the exact same thing and had the opposite result; no ****.
