most power out of 93 octane
i would say at your ci you could probably put a 750rw or so tune and feel pretty good about whatever they put in the 93 oct. tanks these days.... and i would still spray meth anyway.
i know this was not the answer to your question... but i think it is the right answer to the right question
2000 TRANZAM Member here made 893rwhp with 91octane with 408ci and turbo but I believe his engine blow up about a month ago.
IMO you have put alot of work,time and money on your setup and all can go away from a littel detanation.
I say at least spray the METH,
BTW Saw dyno vid of your car its SICK.
Originally Posted by red beast
right now we have been playing around with the tune since the maf maxes out as soon as you hit the gas...I'm waiting for my speed density to arrive, so we went to bp and put in 93....at 12psi and 14 degrees timing I'm at 897 and pegged the dyno at 1000 ftlbs....I'm gong to run c16 and 20-25 degrees timing.....the we will see what it's capable of.....
Wholly *** load's of torque!!! You also have a six speed,correct.
Definatly have a beast on your hand's. Congrat's
Originally Posted by theblur98ss
Nice numbers for sure. You should change the title to highest pump gas 6 speed though.
damn, that's getting it done....
Originally Posted by Drewstein
A well built motor with a decent tune lets the power come easy. I didn't have the ***** to go over 640rwhp with the stock motor on 91 though.
Originally Posted by Zombie
670 on 91 octane @ 15psi 370 cubes and T76
