[look] Car Wont Start!!! Help!
ok. first at WOT the motor would hesitate and guages would go all crazy, so i checked all the grounds (hopefully got them all) and seems to be ok. next day the car wouldnt even start. i gave up on it for a few months and am back at it. i took her to a local shop and they said i have a failed fuel pump, $1200 for parts and labor! so i swapped out the fuel pump myself with a racetronix i also i changed the plugs and wires. charged up the battery and tried starting it, still, it wont start, the starter engages, im sure the fuel pump works. the motor turns over but nothing. i did notice that the guages when the ignition is on, the hazard are lit solid and when i turn off the ignition the rpm and speedo needles go crazy for a little bit. anyone know what the problem might be?
Originally Posted by Dmoney
Did you check the grounds (3) behind the drivers side head????? Also, it could just be your fuel pump relay. Switch your relays....... Take your A/C relay and switch it with the fuel pump relay. They are the same relays.
done both...still same isht. i guess i gotta take it to a shop, again.
