Okay how bout this one??? 427/cam
Okay after listening to you guys and alot of other people I decided to go with a different camshaft. Instead of the 232, 242, 540, 545, 113 lob sep and 111 centerline isky grind I am going with a 244, 248, 609, 612, 113 lobe sep on a 108 centerline. This will go in my 427 with 11.4 to 1 compression and afr 225 heads etc etc. Let me know your thoughts on this one as well thanks, I just read the cam and it has +4 on it as well assuming that means its got 4 degrees of advance ground into it.
D.J.
