summit throttle bodies
anyone heard bad? good things? from them?
they are about 160-190 shipped.
pretty cheap....wondered if anyone has any thoughts/reviews on them??
I got the 85mm satin one. Nice quailty, better then my old BBK one i used to have. It even has the lip right in front of the Blade like the factory ones do. Comes with 2 throttle cams. Comes with new hardware to.
i purchased the 80 mm for $186 plus $11 shipped. its polished, easy to install, the vent tube points up so my rubber hose from the valve cover goes over / above the throttle cable instead of below. easy to adjust the throttle cable just a clip near back of engine, (next to my auto dip stick) loosen / remove clip. it self adjusts, then reclip. i'm no mechanic and it was simple. i'm happy!
there is a aprox 1 inch spacer that reduces 80mm down to fit opening. (less room for a bellows). i have a standard LS6 intake (slp vette version) . mines worked good for a couple of months now, i'm happy.
My experience is that you get what you pay for. Many of these inexpensive TBs have small diameter shafts and bearings, and are made in China? I tried a certain brand and sent it back. I ended up buying one of the new Holley throttle bodies. Excellent quality and built to last!
