Bounced off rev limiter, am i screwed?
I was racing someone and being new to manual bounced it off the rev limiter before I shifted from 3rd to 4th. It bounced like once or twice before I caught it. It seems to run fine , no funny smells, and no warning lights are on. Are there some other things I should check for to be sure? Could you bend a push-rod or valve by hitting the rev limiter like I did?
you should be fine. I was on the rev limiter a bunch of times in my 95k mile 01 camaro. If you miss a shift, that is a different story. And sitting the limiter will cause damage.
You said you hit it while in winding out third gear? You are most likely fine.
The most likely way you would bend a PR is forced overrev (via accidental downshift, and in some cases, you'd be luck to get out with just a bent PR with this)
Boucing on the limiter while free-revving (no-load on engine/ in nuetral)
Bouncing off the limiter doing a burnout or doughnuts.
Originally Posted by ZeroFear
OMFG WTF!! His VIN should be red flagged by carfax as "warning, previous owner was a ********"
gotta love the guy after the burnout imitating the rev limiter.
