Starting in 2nd or 3rd
what rpms are he up to if he is starting in third? I start in second when there is snow on the ground, it helps with traction. I do not believe it is bad for the transmission to start in second.
Tech Resident
starting in second gear is fine. starting in third gear may wear the clutch a little faster since it takes a lot more effort to get the car off. i've started a truck off before in third and it was pretty wobbly; the engine was struggling and it just didn't feel good...
It is hard on the clutch. He's probably slipping the clutch a lot to start out in 3rd! Our 1st gear ratios are rather high. Now it would be a different story with 4.10 gears.
I have 4.10's and wouldn't start in 3rd... would still have to ride the clutch pretty hard... 2nd maybe but I don't see a point unless in regards to Snow which i do start in 2nd.
