Which intake should I get?
Old 07-31-2007, 05:10 PM
litle88's Avatar
Default Which intake should I get?
I am in the market for a FAST intake. But with the MODS in my SIG which intake should I get? the 90mm or the 78mm?
Also how are the typhoon intakes?
Anyone using them?
Old 07-31-2007, 05:12 PM
King Nothing's Avatar
whats are your plans for the car? nitrous? blower? etc
if your gonna run nitrous than yeah spend $1000 on a FAST intake.
Old 07-31-2007, 07:48 PM
litle88's Avatar
probably some nice heads later!
to compliment my cam, and some 1.8 rockers. what would the difference be with a 78 or a 90.
thanxs
Old 07-31-2007, 07:55 PM
01FormulaTA's Avatar
save the money and get the 78mm.....the differences b/w the 2 will be minimal.....there is an article on this, hold on I will try to find it for you....
Old 07-31-2007, 07:59 PM
here it is....http://www.vetteweb.com/tech/vemp_06...tor/index.html
if you read the article the 78mm intake makes 499hp and 487tq while the 90mm version make 501hp and 487tq on an engine dyno, but the 78mm version also make a little bit more power down low in the tests.....here is page 2 with the graphs....
http://www.vetteweb.com/tech/vemp_06...o_testing.html
Old 08-01-2007, 09:49 PM
litle88's Avatar
thanks formula I appreciate it!
What does this kit come with, to bolt on? does anyone know?will I need to purchase anything else?
Is there a write up on this?
thanks
Old 08-02-2007, 01:17 AM
sidewayz28's Avatar
lol why would u get the 78? if for some reason something happends to ur motor and u go with a bigger cubed motor, a 90mm would have much more potential then a 78..
Old 08-02-2007, 11:37 AM
Magnet's Avatar
Your only going to regret getting the 78mm later...either run a ls6 or 90mm FAST. How many threads have you seen saying "got a 90mm, wish i would have gone 78" ? You never see them for a reason..save a little longer and get the one you won't regret IMO
Old 08-02-2007, 11:50 AM
bsf
bsf's Avatar
I am not certain, so you will need to double check. I thought a member here successfully ported the inlet on a 78mm FAST to allow it to match the outlet of a 90mm TB. Something for you to look into.
Old 08-02-2007, 11:57 AM
Ericbigmac83's Avatar
Either stick with the ls6 or get the fast 90, But you really dont need the 90 right now
Old 08-02-2007, 12:09 PM
Formula_Power's Avatar
If you decide on a 78 FAST I will have one in about 2 weeks I will be selling let me know what you decide
Old 08-02-2007, 12:20 PM
Asmodeus's Avatar
Get the Fast 90.. it outflows all the other current manifolds, and is still a restricion on even mildly ported heads. Getting it ported to 290+cfm flow will help if your heads can keep up. The 85mm Typhoon is a good piece, but does not flow like the fast, the 96mm Typhoon MIGHT but I have not seen any tests on that manifold, but it is cheaper. Same TB's bolt up to both.
Old 08-02-2007, 12:34 PM
Retired Street Racer
Matt D's Avatar
Ported LS2 with a NW 90mm TB. That is what I am going with
Old 08-02-2007, 12:38 PM
litle88's Avatar
Thanks for the info fellas.
Ok got it. But is it a bolt on, or do I need to purchase anything else?
