tq arm fitment problems
Long story short, it seems like it is too long. Spohn tunnel mount tq arm, moser 9" housing, spohn adj. lower control arms. I have the control arms adjusted out to 19 7/8" center to center on the bolt holes and I am concerned if I go any farther that they will lose strength. . Any suggestions??
Should I unhook the lca's and hook the tq arm up and then adjust them to fit???
Keith
Keith
adjust the torque arm length at the bushing for the tunnel mount....screwing it out will increase over all length(i think i had to pull mine out 2 turns to get the 1/2" i needed)....for the same token you can loosen the jamnut and screw it back in some to shorten it
