largest stroker kit with stock bore?
Old 07-31-2007, 09:05 PM
427TTA4's Avatar
Default largest stroker kit with stock bore?
like the title says whats the largest stroker kit you can do on an ls1 stock block because I thought it was a 383.Or is it as long at the pistons bore is 3.905.I am kinda on a budget so thast why I wanna keep the stock bore
Old 07-31-2007, 09:44 PM
Super Hulk Smash
JakeFusion's Avatar
You can do a 395 with a 4.125" stroke with some machine work to the block. Just ensure the pistons are designed with the longer stroke in mind with the proper rods. The pistons will need a different ring combo to help with piston rock at TDC and excess side-loading due to the rod/stroke ratio.
Nowadays, 402s and 416s can be had for only a few hundred dollars more than a 395 kit + machining costs. Plus, if you buy the shortblock outright, you then have a complete LS1 shortblock to sell on ebay for a few hundred bucks. At the end, the difference will probably be less than $500. And a 402 will definitely outpower a 395 due to the larger bore, which unshrouds the valves and allows for more flow/power.
Old 07-31-2007, 09:47 PM
NHRAFORMULA00's Avatar
And the pistion in the back next to the reluctor wheel needs X-tra clearancing because of the long stroke
Race your car!
JL ws-6's Avatar
with the potential problems that a 395 would have, you'd be WAY better off going with the mentioned 402, but if budget is gonna make the ultimate decision, go with a 383, that will be your cheapest option providing you are gonna reuse your existing block.
No matter what you do, you increase CI, you will increase power rest assured of that.
Old 07-31-2007, 10:28 PM
Beast96Z's Avatar
Your thinking of going larger by increasing bore and using a 4" stroke, when in fact, your only adding more stroke. The 383 uses a 4" and a 395 uses the 4.125". In either case, the bore stays the same. Cubes come from the stroke. Like Jake said, you gotta be careful with the piston design on the 4.125". There's lots of room for potential problems if not done correctly.
Old 08-01-2007, 02:15 AM
427TTA4's Avatar
uuhmmm.....okay I know the ls1 and ls6 are 346ci so an ls2 is 402ci or which ls block contains a larger bore than the ls1 engines
Old 08-01-2007, 04:47 AM
Race your car!
JL ws-6's Avatar
all the blocks have a larger bore then the stock ls1/ls6 block. so going to any other block, will get you more CI via the bore.
Old 08-01-2007, 09:06 AM
N4cer's Avatar
Lq4, Lq9, Ls2, L92, Lsx.
Old 08-01-2007, 11:17 AM
Dragkid1917's Avatar
a 6.0 l ls2 us a 364 cubic inch not 402
Old 08-01-2007, 11:50 AM
N4cer's Avatar
Duh. 6 liters is 364ci. Do the math. Same for the LQ4 and LQ9. But they will accept the bigger bore and if you put a 4" crank in with a bigger bore, you get a 402.
Quick Reply: largest stroker kit with stock bore?
