changing valve covers what is needed?????
Old 08-01-2007, 04:08 AM
Formula_Power's Avatar
Default changing valve covers what is needed?????
I am changing from 98 perimeter covers over to center bolts what do I need other then the valve cover??
Old 08-01-2007, 08:51 AM
turkey's Avatar
Not to sound like a jackass, but you need heads that will accept center bolt valvecovers.
Stock 98 heads only have bolt holes for the perimeter bolts.
EDIT
Perimeter bolt heads
http://ourworld.cs.com/jrp98ls1/LS1PERIMETER.jpg
Center bolt heads
http://ourworld.cs.com/jrp98ls1/LS1CENTER.jpg
Old 08-01-2007, 12:44 PM
GR33N GoblinM6's Avatar
after you get the aformentioned needed 99+ heads.. you need the coil brackets and bolts.. along with the 4 center bolts for the valve covers.
Old 08-01-2007, 02:00 PM
turkey's Avatar
Wow, how did I forget those? Valve covers really dont work too well without the bolts.
If you want you could get the coil re-location brackets too.
Old 08-02-2007, 12:15 AM
Turkey yea I know you weren't trying to be an *** i have a 98 engine now and i am getting a 408 but the new motor comes with heads that are center bolt style so i just needed to see what was needed to make the conversion. Trying to get ecerything in place for the swap so i dont get hit with surprises
Old 08-02-2007, 12:17 AM
So i can reuse my actual coil packs then right?
Old 08-02-2007, 01:07 PM
yes they will work. MAKE SURE you get the specific bracket bolts for the coil packs.. because the 98 bolts are a different thread pitch
Old 08-02-2007, 05:46 PM
Thanks that is good info tohave now does any know a sponsor or anthor parts store that offers some kind of kit or anything?
