ATI pulley bolt, washer, and pin question
Do you know where I can buy these?
I think the bolt and washer can be bought at any hardware store (maybe) ... but where can I get the pin?
Thanks,
-Mike
Thanks,
-Mike
Originally Posted by Mark98SS
Try EPP, don't even think about a hardware store bolt
To me, the pin will lock the whole thing down so the bolt is just there to tight thing up together.
Just like the crank bolt, w/o pining the crank bolt, you will put down a ton of torque to keep it there. After pinning the crank bolt, it only needs 150 lbs of torque.
Thanks,
-Mike
You need to find out if the ATI re-usable bolt is just a grade 8 or something more. The washer that comes with the ATI bolt is much more than anything you can buy at a hardware store. It's such a critical piece that I wouldn't skimp on it, IMO.
