Theory question on boost.
Old 08-02-2007, 12:49 AM
SPRAYED 01's Avatar
Default Theory question on boost.
Ive heard that a certain amount of boost let use 14 pounds can be less efficient on one setup and more efficient on another setup. If there is 14 pounds of boost in the intake isnt that always the same. Why is it that some people with different turbos or superchargers with the same boost level make different power
with every thing else equal.
Im in the process of my first turbo project and i was told the turbo maxed out at 14psi but wasnt very efficient at 14psi. What exactly does not efficient mean, its always 14 psi right?
Thanks
Alex
Old 08-02-2007, 01:10 AM
black98ws6ta's Avatar
Efficiency is used in discribe several different things. Usually with ls1 motors it is related to exhaust backpressure and compressor flow..a turbo can lose power at 16 psi compared to 14 psi if the charge is super-heated. Same thing with the exhaust side....if the exhaust side of the turbo is small for the motor it is installed on, it can cause huge backpressure which chokes power.
Old 08-02-2007, 07:09 AM
SonofaBish's Avatar
Also, you mentioned 14psi on Supercharger vs. Turbo...
The turbo car will typically create more power b/c the turbo is more efficient.. It actually takes horsepower to spin the supercharger, therefore decreasing the efficiency
Old 08-02-2007, 08:32 AM
calculon's Avatar
Because different turbos and superchargers have a different mass flow rate at different boost pressures. Boost pressure doesn't create more power, mass flow rate of air creates more power because it allows you to combine more fuel with it for a given AFR, therefore you are releeasing more energy per combustion event. This is a simplification, because the pressure does affect things like the intake tract air dynamics and fuel atomisation that also affect power production, but I think the simple answer that I gave you is the one that you are looking for.
If all that mattered was boost pressure, nobody would be using big turbos, everyone would be running tiny turbos for the quicker response.
Old 08-02-2007, 08:52 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Boost/PSI is just a simple matter of how restrictive the entire system is given the size of the motor. As the previous poster stated, there are differences.
Old 08-02-2007, 10:18 AM
SPRAYED 01's Avatar
Thanks for all the info, really helps. Hopefully ill be FI pro in no time.
Old 08-02-2007, 11:35 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
1) 14 psi with you running a T76 is different than if you were running a 88mm thumper. For example my turbo is a lot bigger. But you need to be in the efficiency range of a given turbo to make good power as well. I'm sure someone can chime in and state it better than me.
2) Boost is a value. Kurt from W2W summed it up best once, when he told me that 15psi could effectively double my engine horsepower since I'm cramming double the amount of air through it. It's a good rule of thumb.
Old 08-02-2007, 12:36 PM
red beast's Avatar
bsm is right on the money...boost in psi represents backpressure....if you have a 75 mm throttle body and 80 mm maf and your boost gauge is reading 14psi and you install a 90tb/90maf then it's not uncommon for you boost psi to go down a couple of pounds because your intake track is less restrictive now, but you will make more power....hope that made some sense....
Old 08-02-2007, 12:49 PM
M3 Muscle's Avatar
You also have to think about the restrictions in the exhaust (turbine efficency). One turbo might be able to make 15 lbs boost w/ 40 psi exhaust pressure, and another make 15 w/ 50 psi exhaust pressure. That is going to play into the BIG equation.
Old 08-02-2007, 07:43 PM
Bird-Of-Prey's Avatar
Just as stated, boost is a measurement of restriction. This is not something you should be after. Flow is what you should be looking for both on the intake and exhaust side. Boost will find it's way in on it's own. Keep the backpressure on your exhaust as low as possible along with running a properly sized turbo to keep it within it's efficiency range and IAT temps as low as possible and you can't really go wrong.
Old 08-02-2007, 07:58 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
just something to think about if what ur saying is true than a 1.6 liter honda pushing 14psi should make the same hp as a 6.0 liter ls1 motor
Old 08-02-2007, 10:17 PM
great421's Avatar
boys, Boys, BOYS!!! (Did anyone get the Robocop reference?)
PV = NRT
14 PSI @ 250 Degrees F is NOT equal to 14 PSI @ 95 Degrees F
Thermal and mechanical efficiency are your friends! Whatever is the most efficient will make the most power (and, get the best gas mileage too!).
Now, let the flaming ensue from those who have faster cars than me and therefore must know more about all things automotive than all automotive engineers combined!
Old 08-02-2007, 10:18 PM
SPRAYED 01's Avatar
I think you missed the last 5 words of my quote "with every thing else equal." Including engine is what i meant.
Old 08-03-2007, 01:07 AM
Dan Stewart's Avatar
Some of the other posters here have done a great job of explaining boost related backpressure or boost stacking and how it affects efficiency.
Remember that an engine is basically an air pump (although simplistic, it helps us understand the function better).
The more air VOLUME that you can move through the engine, the more power it will develop. Now increasing pressure usually results in increased volume only if the engine can move the higher volume through it.
Volume flow is measured in CFM (cubic feet per minute). Now imagine you have two pieces of pipe. One is 1 inch in diameter and the other is 2 inches in diameter. If we force air through the two pipes at 14psi, which one will move more volume? The 2 inch, of course. The reason being is that it takes a larger volume of air to pressurize the 2 inch pipe to 14psi than the 1 inch pipe.
The same thing applies to a combustion engine. An engine with better flowing heads, intake, and exhaust will flow more volume of air at 14psi than one with restrictive respective parts. Since it flows more volume, it will produce more power.
Old 08-03-2007, 01:44 PM
great421's Avatar
Default Go to the head of the class!
Well done.
Volume not pressure; Actually the number of Moles of O2 consumed per unit time, but we don't want to make people remember their chemistry and physics classes or Avogadro's Number...
Remember, efficiency and amount/volume.
A more efficient setup will make more power with the same volume of O2 used, while a greater volume of O2 used can overcome a lack of efficiency. That's why a weaker car can win at the dragstrip if the suspension, tires, and gearing are more efficient at getting the power to the track vs. a very strong car which spins the tires.
That's why turbo guys like turbos vs. superchargers - they (typically) are more efficient by virture of zero drag on the engine.
Old 08-03-2007, 01:45 PM
red beast's Avatar
wow, that was a great response...
Old 08-03-2007, 04:29 PM
SPRAYED 01's Avatar
Ya, thanks alot
That makes alot of sense.
Basically the person i bought my turbo kit from make 550hp and 650ftlbs on a mustang dyno. He used a stock cam,ls1 intake and stock heads. i was trying to figure out if my ls6 intake better heads and cam would make a big difference in power.
Im using ported and polished 241s with a 224/228,585,590 on a 115lsa.
Old 08-05-2007, 08:26 PM
peter@aps's Avatar
Alex, The link below may help you understanding of pressure ratio vs mass air flow.
Peter
http://www.airpowersystems.com/350z/turbo_flow.htm
Old 08-05-2007, 08:53 PM
SSANDTA's Avatar
I can give you real world findings on my car this is a supercharged car but it shows what better flow can do for you. The only thing I changed in my setup was the heads they flow about 35 cfm better than my old heads and I picked up about 35 rwhp peak and 60 rwhp under the curve. I also lost 3 pounds of boost from the better flowing heads also.
Old 08-06-2007, 10:37 AM
red beast's Avatar
that's exactly what I was talking about on one of my earlier post...now if you increased the boost back to your original starting point (to get the 3 psi back) your numbers will be awesome...thanks for sharing.....
Quick Reply: Theory question on boost.
