Eastern Members - car trailers- Open and Enclosed
View Full Version : car trailers- Open and Enclosed
burbanman
08-02-2007, 01:57 PM
The open is the 23ft deck, that I bought used back in Sept 05. Its a great trailer and tows easily, I have hauled everthing from mustang/camaro's to lightnings and a 3/4ton suburban. It also has a unique hold down system at the front of the trailer. Could use a few things to be perfect, but for the $$ it is very hard to go wrong. I am looking for $1000 for it, as-is.
Also, gauging interest in my enclosed. It is a 2006 Wells Cargo MT2424W-1000, 24'. White/w black stripe, has upgraded dual 5200lb Torsen axles, 4 wheel brakes, break away, curb side door, and street side door for getting out of the car while in the trailer, good tires and front/rear tie downs. Still has 1 more year of "complete" warrantee(like bumper to bumper on cars). I have over $8000 in it, asking $6000
From the wells cargo site:
* Rear Ramp Door with Dual Spring Assist Cables
* Plywood Ramp Toe Extension
* Rear Swing Down Stabilizer Jacks
* Reinforced 4’ Recessed Beavertail
* 36” Side Door with Full-Length Cam Lock
* Recessed Step at Side Door
* 3/4” Exterior Grade Plywood Floor (undercoated)
* 1/4” Plywood Interior Sidewall Liner
* 12-Volt Dome Lights (2) with Wall Switch
* Sealed Beam Oval Tail Lights
* 18” ATP Stone Guard with Intergrated Corners
* Smooth Aluminum Fenderettes
* .030 Prefinished Aluminum Exterior Skin (11 colors)
* Non-Corrosive Mechanical Fasteners
* Galvanized Steel Roof
* Tubular Steel Main Rails
* Full Height C-Channel Crossmembers & Outriggers
* Chassis Fully Primed and Painted Silver
* 3-Piece A-Frame with 2 5/16” Ball Coupler Hitch
* Top Crank Jack Ram Hoist with Sand Pad
* D.O.T. Compliant Safety Chains with Clevis Slip Hook & Latch
* Torflex® Rubber Torsion Tandem Axles (10o Up Trailing)
* E-Z Lube Hubs
* 15” Bias Belted Tires on Silver Mod Wheels
* Electric Brakes with Weather Resistant Wiring
* Wet Cell Battery Breakaway System
* 7-way Pigtail Connector
* Flared Stripe Racing Graphics (choice of red, black or blue)
looks like this one, except stripe is black:
http://wellscargo.com/motortrac/images/mt1000_front.jpg
I can get actual pictures if some really needs them, or you can come to Frederick to see in person.
iverson387
08-02-2007, 10:38 PM
can u send some pics of the deck trailer to iverson387@aol.com anything wrong with it
highflyin
08-03-2007, 10:46 PM
I would also like a few pictures of the open trailor.Is it a dovetail trailor or flat?
burbanman
08-04-2007, 02:56 PM
Hey Guys, sorry about not having any pics when I posted...... pics of the open trailer can be seen at: this link (http://good-times.webshots.com/album/560136546QKkBtI?vhost=good-times)
