AC need to come out to do cam swap?
its hottttt out. i took off my ac lines when i did header change. i want to go get it charged. but i am about to do cam swap in a month or so. will i have to take any lines out for Air conditioning when i do springs retainers and cam swap.???
Generally yes. The radiator and AC unit in front need to be removed to get the old cam out and new one in.
If your AC system has been opened, you really should have your AC drier changed (e.g, the silver tin can with the black hoses). After drier replacement, the system should be vacuumed down for a few hours and only then should it be recharged with freon.
I have a vacuum pump that I bought for $300 but most AC shops have these. Don't go to a hack who merely re-fills the system with freon.
Well I only disconnected it from the front to remove the raditor & then used a Autozone recharge kit for $30 to refill it & it blows colder now than before. Very easy to do & cheap. You don't need to remove everything & you certainly don't need a $300 tool to recharge it.
Pretty good I guess. I haven't had a issue & I just bought the cheap cans of recharge with a gauge on it & followed the directions.
It's working perfect so far. No funny smells & it gets cold quick.
I also ended up with a quieter valvatrain than stock after a set of heads, cam, 7.4 pushrods, stock rockers & Partiot Gold dual springs. No sewing machine for me so I guess my luck is pretty good with the LS1 so far. Every mods has worked perfectly. Hell even my LT's went in without a fight.
Recharging a system without vacuuming the air out is a bad idea. Yes, it will work, but it will cause problems eventually.
You guys are crazy, I've installed 4 cams and never touched the AC system. My latest project was to install a 408 through the top with heads and dampener on and didn't touch the AC.
Originally Posted by 99DWPTA
thnks guys. is it easy to use the vacum you rent from autozone? is that the only thing you need to do before recharge it with freon?
First of all take it somewhere to get it recharged, doesnt cost all that much and its worth gettng done right over taking the cheapo way out.
Second... you dont need to open the ac to do a cam swap but you do hve to move it out of the way. You'll bend the tube a little and they take it just fine for the first 3 times or so but on the 4th time one line will break...
If I were going to do a swap for someone I would tell them it's thier choice. Disconnect the line or take the chance it might break. Most likely wont break for the first time or two
