A/C problema
Do the vents not blow cold? How about the top dash vents, do they work? Or is it just the floor vents? It could be that PITA little plastic thing that always goes bad. Check for vacuum leaks, since the AC is vacuum controlled.
If the compressor clutch is not engaging, then it could be a dozen different things causing that, low side switch, high side switch, relay, fuse, the clutch coil itself, etc. etc..
High pressure switch is usually on the compressor itself. Try just jumping the low pressure switch at the connector with a fused test lead and see if the compressor doesn't come on.
Originally Posted by ricardo colon
how to test presure switch if they are good or bad
that would engage the cluch , but how do i know if the switch itself is bad
TIC TAC TIC TAC ANYBODY HOME
Go to a parts store buy the a/c refill with a gauge. $30 get us a pressure reading
TIC TAC TIC TAC you there
Some people man gee wizz my a/c no work but I want to add freon with out checking the pressure. Then I expect the internet to come up with a magical diagnosis for me with out giving them proper info.
that would only engage the cluch , i want to know if the switch itself is bad or not
