sportline vs prokit on birds
pro kit rides good and is plenty low and the spring rates are decent for all around sportlines are low as *** good luck gettin rubber back there. now my vert is heavier so pulled my rear pro kit put the factorys back in with the hose mod in the rear...and i have 305's in the back and still rub under launchs
Originally Posted by z28bryan
Any reason why your completely sold on one of the Eibach sets? There's a ton of different spring choices for the 4th gen. Much better ones are available.
is anything less expensive and just as good? i'm on a tight budget at the moment.
If that's the case then don't bother. Keep what you have now.
STRANO!!! i always had the same questions and everyone told me the sam thing...strano.
the only names ive seen that are universally approved of on this board are AFN fiberglass, strano, and koni.
Here's my Firehawk, it has sportlines on it. It sits to low in the front and the tires lean in. I hate that. I have some Strano springs waiting to go on, saving up for some struts now. The car looks pretty good in the pic, but you can't really tell how low it is. I have some more I will post.
I have the pro-kit. It rides nice with the bilstein shocks I have. However it seems like the springs are a little too soft for the amount they drop the car. I'm thinking about getting new sway bars.
