Best first suspension upgrade...
Old 08-02-2007, 10:03 PM
Vrbas's Avatar
Default Best first suspension upgrade...
Just curious, i've been fiddlin' w/ the engine plenty (Headers, intake, cam and heads coming this Xmas, 3.73 rear), but i want to make sure all that power connects w/ the ground and doesn't fly up in a cloud of smoke.
So i ask, what should be my first suspension upgrade for my 99 WS-6? Also, how much do you think it's gonna cost me to stick 400+ HP to the ground (daily driver)?
Old 08-02-2007, 10:05 PM
crazboy99's Avatar
lower control arms and relocation brackets seemed to help me a little bit, costed a little over 200 (i think)...next on my list is qa1's
Old 08-02-2007, 10:12 PM
Calico's Avatar
subframe connectors seemed to help some. I would recommend them.
Old 08-02-2007, 10:14 PM
02silvaZ's Avatar
a panhard bar and LCA's are a good start, gets that rear end straightened out, torque arms are helpful too
Old 08-02-2007, 10:17 PM
The Black Mamba's Avatar
9"...
crazboy99's Avatar
the new issue of GM High Tech covers suspension pretty well...madman knows his stuff...just got done reading it at work
Old 08-02-2007, 10:33 PM
WS6Jayson's Avatar
Lower control arms
Old 08-03-2007, 12:57 AM
Vrbas's Avatar
Originally Posted by The Black Mamba
9"...
Yeeeeaaaah, about that.... not lookin' to dish out > 1 grand.
As far as lower control arms (i'm guessing that's rear, not front) and subframe connectors, should that run me over $300?
Old 08-03-2007, 01:08 AM
fuseone's Avatar
i would start with subframe connectors
Old 08-03-2007, 08:43 AM
kyle91z28's Avatar
Sub-Frame connectors....probably 120-170ish $
Old 08-03-2007, 09:08 AM
jmill96Z's Avatar
Chassis mounted Torque arm
Old 08-03-2007, 10:12 AM
fastvert's Avatar
Well im assuming from your original post you want a suspension for straight line traction, and not corner carving/handling.
In this case ditch your front sway bar, add LCAs, torque arm, and or Panhard and some soft sticky tires and you have a good start. look at UMI stuff if you wanna save money they are pretty cheap compared to alot of the others..
Old 08-03-2007, 10:30 AM
Guido1's Avatar
i go with LCA, subframes, torque arm, BMR, Spoohn, UMI good names in f body suspension
Old 08-03-2007, 10:31 AM
Guido1's Avatar
u can wait on the panhard bar until you lower your car, one of the main purposes of the panhard is to center the rear end on lowered vehicles
Old 08-03-2007, 10:33 AM
5301113's Avatar
+1
Old 08-03-2007, 11:38 AM
BonzoHansen's Avatar
+1
x2
Old 08-03-2007, 03:41 PM
Vrbas's Avatar
Assume i go the cornering and carving route...
Thanks for the help.
Old 08-03-2007, 03:59 PM
TheLS1Kid's Avatar
PHB, LCA's and relocation brackets are a great start.
Old 08-03-2007, 04:09 PM
lilbuddy1587's Avatar
Subframes and a Torque arm.
Old 08-03-2007, 05:34 PM
fastvert's Avatar
if you wanna corner carve, it cant really be had on the cheap...
good springs/shock combo. new front/rear sways
its hard to do both... read the sticky in the suspension section
i tried to comprimise and get a decent all around setup in mine, now im having problems deciding on a good all around shock/spring combo... seems they are either for cornering or drag setups, and my car is a little of both as i suspect many of ours are. im leaning toward HD Bilsteins, and a front lowering shock and the heater hose mod for the rear with the stock shock... i dont mean to hijack, its just ive been thinking about this topic lately...
