Average Procharger boost with 4.5 pulley?
Hey guys. I'm installing a procharger on my WS6. D1SC with 3.5 IC. It is stock except for the cat back. I know that a lot of different things determine your boost level. On average what will a 4.5 pulley give you. I don't want to go over 8psi. I have a 4.25 but I am not sure if this will be to much boost. Anyone have a 4.5 pulley if that is what I need? Thanks for the help.
Call EPP and talk to them about what you have and they should be able to help you out. When I was running a 4.1" pulley with a GT2-3 cam and see about 6psi or so. Every car is going to be different.
It's an 8 rib kit. D1SC 3.5 IC It is a stock engine. So I know it will be less eff and have higher boost. I'm trying to figure out which pulley to start with. Hey Bob. I sent EPP two PM's and also emailed through your website then tried calling but you were gone for the day so I left a message. I never got a response from any of it. You've been very helpfull to me in the past. I know that you are a busy man.
