Forced Induction - 408 with Procharger??
TN94Z
08-03-2007, 07:43 AM
I will be building a 408 over the winter and plan on running a procharger next year. My question is, in the build what do I need to watch for and what do I need to be aware of as far as the engine build goes? Any extra precautions to take? I will be running a pretty big procharger...but I haven't decided which one yet. Thanks
You may want to try searching the Forced Induction section on this site.
The Black Mamba
08-03-2007, 10:55 PM
Just make sure the CR is low and don't make the mistake of getting a D1 or P1. Get the F1 straight from the get go and you will be MUCH happier...
TN94Z
08-04-2007, 08:14 AM
I have been reading it all week. But I haven't come across anything like what I was looking for. And I have had no luck searching for anything in a long time. Seems like it is broken alot. Thanks
My D1/408 combo has made really good power, better than some peoples F1 setups. A D1 is definitely not a mistake, and unless this is a max effort drag car, either blower is going to be too much for the street anyway.
To the poster, one thing my builder did was go with 1/2" head studs to help with clamping.
TN94Z
08-04-2007, 12:12 PM
This is a max effort drag car. It will never see the streets. I will definately go with head studs. Thanks
98transguy
08-04-2007, 12:52 PM
if it is a max effort drag car go eith f1-c or f1r
It sucks that search is crummy on this site. I don't know much about forced induction, but look into lowering compression ratio.
Blownramair
08-04-2007, 02:59 PM
ill be doing a similar combo with a ls2 block over the winter as well... havnt made up my mind if ill be getting a procharger or a turbo yet... when i get this combo going - ill let ya know what im finding out... money will be tight so this may take longer than i think to build...
ty_ty13
08-04-2007, 03:09 PM
if this is a drag car you want higher compression... atleast 9.5:1 this will make alot more hp in the midrange and peak....
WickedC5
08-04-2007, 03:36 PM
:lurk:
comecorrect
08-04-2007, 04:13 PM
I would start with at least a F2. Run a vac pump, min 2" primaries / 3 1/2" collector headers, A/W intercooler or run on alcohol, blower cam, ~9:1 compression, 1/2" studs MSD digital 7, Fast system, ect.......
In a light race car 7 sec timeslips!
MIKE
The problem on the LS1 f body cars has been the widest belt has been an 8 inch. With the 8 inch wide belt I really don't recommend going any bigger with the blower than an F1A. ATI Performance Products have just recently come out with a 10 rib wide belt assembly to use with ATI ProChargers on our f body's, which is going to change everything! Bob
ls1290
08-05-2007, 08:08 PM
That is a lot of supercharger. I think a 454 would not be able to run a F2 to it full potential let alone a 408. A F2 flows 2700 CFM which is 700 CFM than a F1-R, 950 CFM more than a F1-C, and 1100 CFM than a F1.
I would look at a F1-C or a F1-R if you want to go pretty radical in a 408.
Keith
comecorrect
08-05-2007, 11:58 PM
Keith
I run a D2R with 408ci in my stang. I believe it's rated at ~2800 CFM. For a race car I wouldn't consider anything smaller than a F2. The Ford guys are using F2's on smaller engines and making good power. For a street car I would have agree with you. However I would run a F2 on the street but I'm a little crazy.:twisted:
MIKE
Pro Stock John
08-06-2007, 12:38 AM
10 rib would be awesome, those guys are really in tune with the market.
TN94Z
08-06-2007, 07:19 AM
I haven't heard anything about the 10 rib setup..hmmm.
The F1-r is the particular one I had in mind. Not set in stone or anything. Thanks guys. This is the kind of input I was looking for.
So higher compression like 9.5:1 for a drag only car??? I had thought about an LS2 block for my build, but wouldn't the iron block be better with the higher boost?
ls1290
08-06-2007, 08:10 AM
That is a greatly debated topic. They are lots of LS2 blocks out there, at 402 CID, making good power. I myself when with a LQ4 block for its extra strength.
Keith
ls1290
08-06-2007, 08:12 AM
OMG, what kind of power does that thing make.
Keith
comecorrect
08-06-2007, 08:29 AM
Keith
The D2R was rated at 1600 HP and a max speed of 53,000 rpms. With it slow max speed and the fact that it doesn't like to to be over-spun. I doubt it could make 1600 HP. It could make 1100 RWHP but you had to lean on it. The F2 is a better blower and makes more power. I run a 50mm cog pulley setup. I wouldn't used a ribbed belt on a race car. Run a good BOV and it with work great. Good luck!
MIKE
BlackScreaminMachine
08-06-2007, 09:03 AM
At that level of power, wouldnt a Cog setup be better in the end? Or is it just too much a PITA for LS1 fbodies?
Steve Burger
08-06-2007, 09:45 AM
Cog drive would be best. Even a 12 rib would be a step up. I have talked to a lot of people at Procharger and have been told that there will be no improvement over the 8 rib setup in the forseeable future. There is no market for it.
That's why I am rethinking and may go turbo.
Websy21
08-06-2007, 10:34 AM
I think its all on goals, there are some people on this forrum with goals I couldn't even dream about. I am going 408 with a d-1, well to begin with anyways. This will be pretty much a street car and I think I will be content with the power. I absolutly do not wanna go turbo for the street. So if a future upgrade is needed, then F1 it is. I have searched and talked to a couple guys on here with this combo and they are making great power while barely even running the d-1, 8-10psi. With the right set up, h/c, etc. You can make you results alot more efficient. Its all what yor after though so I can't reccommend anything, but it sounds like a f-1 is in store for you young grasshopper if the track will be its home. I have no clue on this one, may be some help here guys, but how would the f-1 be on the street with a 408? I guess it shouldn't be too bad would it?
RA88IT
12-10-2010, 07:07 PM
I went with 408 stroker f1c and 19 -20 psi I'm pushing 931 to the wheels on a safe tune. Go f1 or f2 go big
COPO9560
12-10-2010, 08:00 PM
F1 and bigger would be loud on the street.
Bob@BruteSpeed
12-11-2010, 07:44 AM
Did anyone notice this thread was brought back alive from 2007? lol Bob
blue00ZZleeper
12-11-2010, 07:44 PM
jesus....old thread...guy who brought it back is bran new though lol
TN94Z
12-12-2010, 05:01 PM
This is my old thread. Wow this is old! Man how my plans have changed since then!!
