how far is it....
Old 08-03-2007, 10:19 AM
TA4EVR's Avatar
Default how far is it....
what is the measured distance from the ground to somewhere on the car that i can tell what a "stock" ride height would be. my car sits so crooked i can't tell if i want to drop it or not. how far is it from the ground to like the ground affect piece on the door for example? thanks!
Old 08-03-2007, 02:33 PM
Viper's Avatar
Most measure from the lip of the rear wheel to the ground. 12 noon on the wheel. Stock can be as high as 28", lowered cars see 26-1/4" depending on the springs used.
Old 08-03-2007, 03:20 PM
TA4EVR's Avatar
28 is about stock tho??
Old 08-03-2007, 04:16 PM
Viper's Avatar
Factory specs are about 28" in the back and 27.5" up front
Old 08-03-2007, 06:12 PM
Copy & Paste Moderator
VIP1's Avatar
Check out this thread on where to measure and comparison to others:
https://ls1tech.com/forums/suspension-brakes/725347-does-your-car-have-best-stance-come-inside.html
Here are my specs:
Originally Posted by vip1
Stock Ride Height.
Suspension Mods in sig.
:::::::::: Fender :::::: Inside ::::: Fender :::::
:::::::::::: To ::::: Wheel Well ::::: To ::::::::
:::::::::: Ground ::::: To Tire :::::: Tire :::::::
**DRIVER**
FRONT::: 26.75" :::::: 4.25" ::::::: 1.75" ::::::
REAR::::: 27.75" :::::: 6.25" ::::::: 2.75" ::::::
**PASSENGER**
FRONT::: 26.75" :::::: 4.00" ::::::: 1.75" ::::::
REAR::::: 26.75" :::::: 5.25" ::::::: 1.75" ::::::
Interesting that only my driver's side rear is 1" higher.
(Probably for the theory that it'll level out with a driver.)
Some people on here that have measured their stock ride height have come up with higher numbers than mine.
I think my ride height is low enough. I don't want my car any lower than it is now.
