Comp 918's or PRC Double's?
Old 08-03-2007, 10:55 AM
WS6.Jay's Avatar
Default Comp 918's or PRC Double's?
I have the 233/239 .595/.605 112lsa cam from TSP. I am about to slap on a set of PRC 5.3L Stage 2.5 heads. I am currently running the 918 springs with my stock heads, the PRC's come with PRC double springs rated to .650 lift. Should I swap my 918's to the heads or keep the PRC springs?
Also, will my current pushrod's be the correct length for the new heads??
Old 08-03-2007, 11:19 AM
mvvette97's Avatar
duals for sure
Old 08-03-2007, 11:20 AM
BIG_MIKE2005's Avatar
Duals without a doubt. Anytime you go over a 590 lift I suggest goin to a dual spring just for piece of mind.
Patriot offers a full kit for $255, but since your goin TSP, just add the dual springs to the heads.
Old 08-03-2007, 11:33 AM
DONAIMIAN's Avatar
If your not gona check the springs like you should, then go with the duals. But the singles are sufficent.
Old 08-03-2007, 03:30 PM
JPH
JPH's Avatar
with that profile, and assuming your are going to turn the motor over 6K, diffently duals.
