Vinci Tuner - Stock Cam vs Hi Perf Stock Cam ?
stock is stock pcm program hyper stick cam is for all cars with mod intake exhaust and induction ls6 cam its safe to run this on these types off cars for extra hp if you do not have a ls6 cam down the fuel by 10 % it should put you in range
stock cam is your stock tune. by using this, it allows you to modify it with the timing and power enrichment settings of the stock file.
the hiperf/stock cam is a tune above the factory tune.
here's write up i did on the vinci tuner
http://www.stealthram.com/vhptuner.htm
Is the high performance stock cam tune ment for a "stock car" (max power tune)?
Or were other mods used to get the tune. Ie. lid, exhaust etc . . ?
How exactly did they tune for the high performance stock cam tune.
All details please.
All details please.
vinci and crane used over 28 cars and over 1000 hours dyno and drive ability tuning to develop this tuner. there were various configurations used to lay a good average starting point on each tune.
yes, it is designed for the basics. but, don't limit yourself to what the basics are. back when i installed heads on the wife's car, with the stock cam, i ended up using cam #3 to get the most out of it.
