Cfm
Old 08-03-2007, 07:07 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Default Cfm
Anybody know the CFM of the stock cooling fans?
I installed my Be Cool radaitor today and the core pushes the fans about one inch closer to the engine. My EWP occupies this space and I'll have to mod or replace the fans and/or shroud. Any ideas?
Whats wrong with search? Usually, it times out without results. When it works, it shows results from all forums, not just the one I selected.
Old 08-03-2007, 07:47 PM
FASTFATBOY's Avatar
Trim the fan shroud, keep the fans if all possible.
Many have done this, including me on a buddies car.
Search is down because they are at the limit on the server. And have it shut down.
David
Old 08-04-2007, 02:19 AM
Paul Bell's Avatar
Won't work, the fan blades themselves would be into the EWP motor.
Old 08-04-2007, 07:27 PM
FASTFATBOY's Avatar
Unless you have a "heavy duty" (longer) Meziere pump, it will work.
It will not hit the blades, or at least the couple I have done didn't. I just trimmed the fan "cage"
David
Old 08-04-2007, 11:02 PM
Paul Bell's Avatar
Thanks fastfatboy, I guess that's it then, I have the HD Meziere pump.
Still, nobody here has CFM info on the stock fans?
Quick Reply: Cfm
