I hope this is it...
This might get long.
I've been chasing a gremlin for over a year now and I think I might have found him. My 2000 SS M6 has been experiencing detonation at WOT accompanied with black smoke for a while now and a SES light DTS P0430 or DTS P0420 that refuses to go away. So, to deal with the codes I replace both cats, clear codes... Codes comes back. Alright I say, and then replace all four 02's, clear codes... Codes comes back. WTH? OK I say, something else is killing this equipment. I come to reckon that the PCV system is responsible because the engine is trying to burn oil in the air/fuel mixture thus making the SES show a faulty 02 or Cat. I install a catch can and Seafoam the car to remedy this situation as seen in pic below.
It seemed to help for a couple of months as the pinging and smoke was reduced significantly until... the code came back. This time it's just the 0430 and our search function wasn't working to see if I could get anymore clues as what is going on. Today I up the hood while it's running to see if there is a vacuum leak which might explain the WOT ping and a somewhat rough idle. With a two foot piece of fuel hose held in my ear I noticed there a hissing sound coming from the EGR tubing that runs into the manifold. I undo the one bolt that holds the tube in place and see that there is some slop in the seal. Now, it's Saturday Night and the Dealers aren't open tomorrow, does any one know the part # to this rubber seal?
1 Post
wow i see somebody else also went cheep like me and bought a damm ebay catch can dat was like $30 wow that stupid catch can gave me so many vacumm problems, make sure u put rtv sealer on the top two adapter fittings and tighten down every singe bolt and nut on that thing or else you will get some major leaks o and you might as well do the egr mod check out installuniversity.com
Originally Posted by QuickdomesticRacer
Why not just do the !EGR mod. GL.
check your MAF sensor. somthing is throwing your A/F off, so start with sensors and ****. O2's, MAF, even the IAC. i dont want to think its a vac leak, because with the black smoke, obviously you got a rich mix. i dont think its your cats either, because i find it odd for it to throw both banks at the same time. honestly, since yours is a 2000, your cats are covered for 8 years, so id take it to the GM dealer and let them look at it. if it is infact the cats, well you got 2 free cats, if its not maby they can give you some insight as to what it is.
1 Post
i think if its pinging problems you might have a problem with your knock sensor's, the sensor maybe retarding your timing, but i know the 98's only had a problem like that so im not 100% sure bout yours
