Drenched my opti... am I screwed?
Old 08-04-2007, 09:12 PM
A-man930's Avatar
Default Drenched my opti... am I screwed?
So in the process of replacing my water pump I decided it would be a good idea to dump coolant all over my opti So am I completely up a creek? I mean, the reason I decided to go ahead and replace the leaky water pump was to avoid frying the opti... very productive Will the fact that I have the negative terminal disconnected and I wont be running the car for a couple of days keep me in the clear? Thanks
Old 08-04-2007, 10:17 PM
infinitebird's Avatar
sometimes it can dry out. just leave it for a few days and see.
other times it's toast.
it's really a toss up at that point.
Old 08-04-2007, 10:44 PM
Speedy's Avatar
No it won't be toast.
Old 08-04-2007, 11:43 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Ive hear people putting hair dryers to them to dry them out if that is your fear
Old 08-05-2007, 04:51 AM
iceman15's Avatar
eh its a 50-50 chance, the only way you can tell is to wait it out and see how it runs. If its miss firing and running like crap then you its out and in with the new, if not then you are one lucky SOB
Old 08-05-2007, 10:36 AM
96capricemgr's Avatar
I would take it off open it up and make sure there is no coolant on the optical sensor. Should be easy enough with the WP off, just need to pull the damper off the hub.
Really though the usual statements about coolant or water killing the opti are GROSSLY blown out of proportion. I think a lot of stupid kids have cursed and replaced a wet distributor that would have dried out and run a lot longer. The opti is just a distributor and ANY distributor that gets wet will act up till it dries out. I used to offroad trucks and drowned the HEI more than a few times. That one is just much harder to get wet.
Old 08-05-2007, 10:55 AM
LT1Falcon's Avatar
i think you will be alright. everytime i wash my car, the engine gets a bath too and ive never had any problems. of course i try to avoid sprying directly at the opti, so you might have gotten it wetter than i do
Old 08-05-2007, 03:20 PM
blackz93's Avatar
Mines has been soaked proabably 4 or 5 times and never hurt it. 267,000 miles on it too!
Although one time (high pressure hose at the car wash) it wouldn't start for a week and a half!
Old 08-05-2007, 04:37 PM
SLawson86's Avatar
tear it down and check for moisture. they are sealed up despite what other people say. it takes a SHITLOAD of coolant to drown one out.
Old 08-06-2007, 01:16 AM
yeah, 95+ are sealed pretty well. Not so much before that. Since he has a 97 it will probably be ok.
Old 08-06-2007, 01:18 AM
Revelation Z28's Avatar
my opti is a trooper!
a russian race horse can **** on it and itll still start
Old 08-06-2007, 02:34 PM
RickyMartinZ28's Avatar
Mine acts stupid everytime it gets wet, every time... it can be humid outside and it'll go nuts...
It always eventually goes back to normal....
Quick Reply: Drenched my opti... am I screwed?
