ignition problem
ignition problem
lately i feel my ignition system is falling apart when im on the freeway in 4th when i give it bearly enough throttle to downshift it goes to realll low rpm then the engine starts shaking the whole car but it doesnt make loud noises and most of the time it idels real rough should i change the opti and plugs?
Originally Posted by LT1Falcon
check for burnt wires first
http://www.geocities.com/reilym/LTCC/
http://www.bailey-eng.com/
http://www.delteq.com/products.htm
Originally Posted by 383lt1impala
well dont on their site say "system is well-proven in its Northstar application with a stock redline of 6500 RPM"
You will be just fine spinning much higher than 6500 with the delteq.
The delteq doesn't actually come with a separate rev limiter (unlike the LTCC) so your redline will be whatever the pcm has it set too.
i like the ltcc kit, if i have a cylinder missing i can track it to that coil,wire,plug,connector,ect...
and it revs to 7k in my Ta, and has a built in retard for the nitrous so the car is tuned for regular driving but pulls the timing when on the spray
but the delteq is a complet kit and my 95 northstar made all it power in the higher RPM
so the choice is yours
