What kind of puller is needed to take off the balancer?
Old 08-05-2007, 12:33 PM
ckyconan2003's Avatar
Default What kind of puller is needed to take off the balancer?
Ima head to o rielies to get a few things, what kinda puller do i need to rent? ( my underdrive pully is stuck on the hub too btw ) also, what oil do i need to put on the camshaft?
Old 08-05-2007, 03:48 PM
infinitebird's Avatar
You don't need a puller to take if off, only if you want to take off the hub too.
For the balancer just unbolt it and pull it off by hand or use a rubber mallet.
Old 08-05-2007, 04:35 PM
SLawson86's Avatar
use two prybars, and pry side to side...
Old 08-05-2007, 04:50 PM
I8ASaleen's Avatar
Hmmm...what if you want to take off the hub? I've tried just about everything and mine must be frozen on...
I had a puller on there with my 1/2 impact wrench torquing on it at full pressure in my air compressor and the thing still wouldn't come off. Any suggestions?
Old 08-05-2007, 04:51 PM
Revelation Z28's Avatar
can you just put the balancer and hub on any way? or you have to TDC the engine?
Old 08-05-2007, 04:59 PM
i meant the hub, my freaking hub wont come off.....its pissing me off cause its the only thing that lies between me and the cam going in...
Old 08-05-2007, 05:01 PM
a 3 jaw puller from autozone will take it off.
Old 08-05-2007, 06:09 PM
x2 this is what I used and it was very easy.
here's what it looks like:
Old 08-05-2007, 07:37 PM
I8ASaleen's Avatar
Huh, hahaha. Yea I bought one of those, and no budge...
I bought the crank hub puller and no budge...
WTF is wrong with my car!!!???
Old 08-05-2007, 08:23 PM
this is what i did and it worksvery well. get the regular hub puller. use the hub bolt, screw it in 2-3 revolutions. then attache the hub puller and make sure that the long puller shaft sits on the heasd of the hub bolt. procede to remove the hub as u should. now you will need to get a longer bolt to get the hub off completely. but this method will get you going without having to use a threee prong puller.
Old 08-05-2007, 09:06 PM
mybluez28echoes's Avatar
If you have an advance auto parts close by they rent the tool, it cost 89 bucks to use it (You're basically buying it and returning it, that's how they "RENT" tools). just make sure to go with $89 in CASH so they can give CASH back, not into your credit card because then it'll take few days. by the way, it's a box with a lot of stuff for future use, I myself ended up using buying it after couple of times, but it's nice to find a place to use a toold for FREE, so why not .
Old 08-05-2007, 11:12 PM
You're not using it right then.
The key is that you have to be pushing into the bolt hole and not pulling out on the hub. What I did was to get a long bolt (I think a 5/8) that fits into the hole and drill a small recess into the head of it (large enough so the puller center can fit in without slipping off), then attach the puller so the center tip pushes on the bolt and into the hole.
You can do this multiple ways but you have to do it so the primary force is pushing against the hub rather than pulling.
