How important are cooler plugs?
Im running an sts at #8 of boost. My timing at full boost was 13-14* and at the time I thought I had tr6's in the car. I've always had a high rpm ping/detonation so I decided to sea foam the car. My plan was to seafoam and then change the oil/ fuel filter, and the plugs. Pulled the first plug and it was a tr55. Which I believe is = to the stock plug. So again my question is how important are cooler plugs on FI? Am I losing a few * timing cause of it?
Cooler Plugs are just a cheap insurance policy.. I dont know if its been PROVEN per say that they are a MUST.... But for 12-15 bucks they cant hurt!
Gap the tr6's @ .035-.036 and your good to go.....
Hope that helps
Hope that helps
the spark is harder to blow out so less chance of detonation.
check the gap on all the plus, 1 out of the last 16 i got was off (0.40 compared to 0.35)
also, do youself a favor, 3" swivel (sp) extension for the back passenger plug
I've done the plugs a few times now and can do the drivers side in like 5 minutes. The pass side isn't too bad I always buy a new A.I.R. gasket to get that pipe outta the way. Back on track now I know that the smaller gap will help prevent blow out. The tr55 where gapped .038" but what about heat range. I'm just wondering if I should get my car tuned again to see if there is moe timing to be had.
I dont think theres enough difference for increasing the timing enough for it to matter..
I would just have them for extra insurance..... Less chance of blowing those pistons up!
