View Full Version : SLP lid
1979transam
08-05-2007, 07:19 PM
im sure you guys have herd the question more than once
but i have a 2000 trans am i got a SLP lid for it and the damn thing dont fit right at all
the front is kind over lapping and the sides are mabey a 1/2 to a 1 sticking up
is there anything that i can do it fix this or do the SLP lids no fit perfectly
thanks
coop333
08-05-2007, 07:25 PM
I don't have a ws6 ( I have a 00 camaro) but i had to put the mass air flow directly into the lid, a bellow boot that was with the lid ( i bought everything used) goes onto the maf.... The lid I bought came off of a ws6 and he said it was hitting his ram air hood a little but was still ok.
BlackBeautyWS6
08-05-2007, 09:22 PM
I have a 02 WS6 and my SLP lid fits perfect!
LSWon00
08-05-2007, 09:25 PM
put up a pic of what you're talking about so we can tell you how to fix it.
Amoretti
08-05-2007, 09:44 PM
My SLP Lid really doesn't fit well either. I know the overlap you're talking about, but the rubbing against my hood is what really bothers me. I have a grinded spot on my lid from where it hits that just flat out looks ugly. I think I just might get an MTI clear lid eventually, those things are sexy.
BriancWS6
08-05-2007, 11:42 PM
I have used my SLP lid on two WS6 cars with no issues with fitment or rubbing. My buddy with a camaro has one too, and his fits nice as well.
5_02ls1
08-06-2007, 01:00 AM
mine fits great....always has.....
kott0n
08-06-2007, 01:05 AM
I see a trend of original ram air cars not having fitment issues.
I will see if I can get a shot of mine tomorrow. It is a non wS6 car and someone added ram air.
myfast70
08-06-2007, 01:28 AM
My buddy has a '02 Z/28 everything stock and rubs the hood. Even took the paint off in one area!
jester177
08-06-2007, 01:34 AM
i had to trim off some plastic on the back by the tabs and force it on to get mine to sit right on my z28
ItsNotStock
08-06-2007, 01:37 AM
I had this same problem with I bought my slp lid until someone told me the "secret." On slp lids the front tucks on the "inside" of the lower box, instead of the outside as you were used to with the stock lid. As for the rubbing on the top where the neck goes to the maf-This is common, and it's nothing to worry about.
Rede
08-06-2007, 04:10 AM
If you have the smooth bollows, make you you jam that sucker right upto the body of the throttle body.
If I remember correctly, there is a slot on the back of the lid's collar or the smooth bollw (I don't recall which piece its on and its 1am here) that fits onto the throttle body. It should fit nicely around a ridge on the throttle body opening... make sure that it lines up correctly and the bollow is ALL the way on the TB and it should fit much better.
As mentioned above, the front lip fits inside the lower air box instead of over lapping the top.
Hope this helps. :)
WS6Jayson
08-06-2007, 03:49 PM
On the front, the lid lip should fit over the filter lip. Push in the lower lip to snap under the lid.
02silvaZ
08-06-2007, 03:58 PM
same thing here
Pewter02WS6
Mine was a bit of a pain to get the MAF sensor to fit into it but I think the smooth bellow was even harder to fit onto the MAF. Mine does stick up just a little in the back but fits pretty good other than that. No rubbing at all. Just work on getting the MAF in there as far as you can. Expect a good bit of adjusting to get everything to fit together correctly. Good luck! And a picture would be good for us to see also
1979transam
08-06-2007, 11:01 PM
i will get pics of it tomarow and show you im sure that will help
but it isent the neck that slips over the MAF its at the front were the little clips are that you snap it down with that is over lapping and on the left and right side it sticking up mabey 1/2 i looks like
i will definatly have some pix tomarow
thanks your yalls help
boofthese
08-07-2007, 05:10 PM
thats what its doing on my SLP lid, the same exact thing
IROC403
08-07-2007, 06:26 PM
I trimed 1/4 in. off the slp bellows, fits fine now.
I almost hucked it in the trash before I did that.
I also didn't clamp it to the t-body. it fits tight enough,
they seem to crack the lid if there too tight after a while.
worked for me anyways, good luck :chug:
1979transam
08-07-2007, 09:04 PM
have pics on a different thread SLP lid problems w/pics is what its under
LS1Silverado05
08-09-2007, 02:17 AM
+1 I felt stupid when I finally realized this..
1979transam
08-13-2007, 08:58 PM
it was the dang filter i had the wrong one in it
thanks for yalls help
mabey next time i wont be such a dumb ass
RacerScott
08-13-2007, 09:33 PM
yup, it took me a couple minutes to figer this out myself, mine fits good :cheers:
metalmechanic
08-21-2007, 02:39 AM
fits perfect, if you have everything in its proper place
