Comp rocker clearance
I had to take a hammer to the inside of the valve covers and put a few divits in the drip rails. Not too big a deal. When I had it apart again I ground down the top of the compcam lock nuts just a little for some extra clearence...
You can take a dremmel and grind off the rivet heads and get rid of the thin sheet metal panel on the underside of the rocker cover. That's where the rocker will make contact. Or you can just use the hammer method or let the rockers reshape the sheet metal themselves. If they're Comp Pro Mags they can handle the abuse.
