Looking to go "Max Effort" cam only.
My car is currently pretty much a cam only setup, and i like the sound of that. The cam is a F11 on a 114lsa. the car is full bolt ons, with a y pipe and a cutout. It does have a good clutch and a Strange 12 bolt with 4.10's. The car has put down 395whp and 389tq on a mustang dyno, so the car is strong. But my buddy has a MS4 cam only with about the same bolt ons, and I just love how his car pulled on me! and he only had a mail order tune! The car is full weight, ac works and everything.
anyways, he is thinking of selling the cam for a stupid cheap price, how well do you think this cam will help me? or is there other cams that will make the power as well?
my supporting mods include:
ls6 ported oil pump
rollermaster double roller heat treated chain
comp oe lifters
futral pushrods
crane dual spring kit
arp head studs
racetronics fuel pump
thanks for the help
Charlie
ls6 ported oil pump
comp oe lifters
futral pushrods
arp head studs
thanks for the help
Charlie
LS1 Tech Administrator
That cam will be a nice compliment to your combo. The only thing you need to add are some better valve springs. I don't think the Cranes will work well with a .650" lift cam. Patriot Extreme duals or AFR 8019s will work very well with that cam.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
You will need shorter pushrods than stock if you're running stock lifters and rockers. A 7.450" pushrod is what you'll need with that cam if running the factory lifters and rockers.
__________________
7.450" pushrods.
__________________
Do you have any track times with that F11 inyour car now? I was curious because I am thinking about running that same cam in my 99 FRC Vette with stock LS6 heads and bolt-ons. You made pretty impressive #s for a Mustang dyno as cam only. Just wondered how it runs at the track?
Be careful with the MS4.... just had a buddy who had one installed, got it tuned and it ran great for about 1500 miles, then he bent 3 exhaust valves while driving normally on the freeway. Make sure you check ptv!! Good luck!
charlie quit being a puss and put the bottle on it
and lose some weight, mine is running quite a bit better now...enough to give you a run on motor
just dont forget all the fun new tunning you will need to do with a different cam. It runs good now and you should not mess with that aspect of it.
Originally Posted by BES Stroked Nova
yeah i hear you on those crane's. with the cam he is selling me the PRC spring kit that came with hte kit from PRC.
PatrickG, are the stock length pushrods the right setup for that cam, 7.400" right? thanks for the info, your car is SICK!
1 Post
well, if i said max effort stock bottom end and cam only, that would be contradictory
If your "cam only" then you are a stock bottom end????
Were you talking about a built "stock cube" motor?? I wasn't sure if I missed something here.
Originally Posted by black00ssFL
What is his lsa on his ms4? What length pushrod did he use? How many miles on his engine? Stock heads? What is his rpm limiter set at? What rpm does he shift at when he's racing/WOT?
