View Poll Results: Which wideband and why?
AEM UEGO wideband
2
8.70%
Innovate LC-1
16
69.57%
Other, please specify
5
21.74%
Voters: 23. You may not vote on this poll
Which wideband?
Old 08-06-2007, 02:08 PM
White.Lightning's Avatar
Default Which wideband?
Hey all,
I am looking into buying a wideband gauge for tuning. Which one is preferred and why? PLease give reasons for your vote.
Thanks
Andy
Old 08-06-2007, 11:19 PM
gametech's Avatar
I use lc-1's and lm-1's for ease of install and low price. HOWEVER, the lc-1 WILL **** up if installed improperly or used with low battery voltage. It has absolutely NO protection against current being fed into the outputs, and it will NOT work if the voltage at the feed wires is low for ANY reason. I work with electronics for a living, so this normally doesn't bother me, but I did have a problem once with a gauge backfeeding voltage into the lc-1 outputs. The lc-1 serial output still worked, but it IMMEDIATELY fried the analog outputs. They are excellent gauges for the price, but if you get sloppy with the install you could end up with a paperweight.
Old 08-06-2007, 11:21 PM
waterbug1999's Avatar
I believe there was some article on pretty much all the widebands out on the market a few months back. And from what I remember, the innovative brand scored the best.
Old 08-07-2007, 11:31 AM
Full-Force's Avatar
I have the Dynojet wideband commander. I like it alot. It will engage nitrous for you and allow you to set the a/f pameter that you want nitrous to be used. Example, if you set it up to only allow nitrous to be activated if a/f ratios is between 11.5:1 - 12.0:1 then it will not engage the nitrous unless the a/f ratio is in that paremeter.
It has a ton of other features as well.
Old 08-07-2007, 09:03 PM
socal's Avatar
FJO
http://www.fjoracing.com/index.php
i looked at them all for a long time and this in my opinion is hands down the best most universal unit 1-8 cylenders, left and right banks ect...
Old 08-07-2007, 09:22 PM
Here is the article I read... they compare AEM, Dynojet, FAST, FJO, Innovate, NGK, PLX, Zeitronix widebands... Interesting article.
http://www.fordmuscle.com/archives/2...tout/index.php
Old 08-07-2007, 10:35 PM
ErikElvis's Avatar
I can never get to pg 2 of that article. Keeps wanting me to sign up for $16. How is everyone else seeing it?
Old 08-07-2007, 10:44 PM
It did the same to me.. I am trying to find a different link about it.
Old 08-07-2007, 11:08 PM
Well, Innovative Motorsports has the same damn link and it does the same thing.. I emailed I.M. and told them that was horse ****!
Old 08-07-2007, 11:30 PM
1320FEVER's Avatar
The LC-1 was a pain to hook-up, but mine works well and is accurate. I like it. If I were to do it again though, I'd pay the extra $100 for the LM-1.
Old 08-07-2007, 11:34 PM
ErikElvis's Avatar
That is horse ****. I see the link everywhere.
Old 08-07-2007, 11:54 PM
It took me an hour or so to hook up my LC1 and the guage. This was after I had the bung welded in though. I thought it was fairly easy to be honest.
Old 08-08-2007, 09:35 AM
svede1212's Avatar
Google is your friend..... http://tunertools.com/articles/FordMuscle.pdf
