A/C & Cruise Control Wire Schematics
Old 08-06-2007, 05:57 PM
BadMonkey's Avatar
Default A/C & Cruise Control Wire Schematics
Does anyone have these somewhere, both of mine have quit working and I need to run teh wires to check for the reason why lol. I put a tread in another section figured I try here too.....
https://ls1tech.com/forums/showthrea...79#post7570479
Thanks guys
Damon
Old 08-07-2007, 12:32 AM
shotty128's Avatar
There is a 15A mini fuse that powers both
Old 08-07-2007, 10:52 AM
BadMonkey's Avatar
Nothing wrong with the fuse. I checked it visually and with my Fluke.
Old 08-08-2007, 07:15 PM
BadMonkey's Avatar
no one?
Old 08-09-2007, 11:58 AM
shotty128's Avatar
Fine if you say your fuse is good. Go to the air compressor relay pull it out. Make sure you have the keys on. Take your dmm put it on (vdc). Connect one end to the negative battery terminal and stick the other in the pin holes for the relay. If the circuit is good from the fuse to the relay you should get 12V on 2 of the pin holes in the relay spot in the box.
Did you get power in 2 spots?
Also stick something like paperclip in the where the fuse goes. only in one hole. measure that to the negative battery terminal. it should only be 12V for one of the 2 holes that fuse goes in.
Is it 12V in one of the holes?
Then get back to me with your results.
Then I can tell you the next steps to find your problem.
