Lubricant for solid bronze pilot bushing?
Old 08-07-2007, 12:29 AM
Gary Z's Avatar
Default Lubricant for solid bronze pilot bushing?
Does a solid pilot bushing need special grease?
Old 08-07-2007, 07:44 AM
cam
cam's Avatar
no grease they are self lubricating
Old 08-07-2007, 12:37 PM
chevroletfreak's Avatar
Why wouldn't you? I don't remember what kind I used, but you definately need some lube. I think I just used regular GP grease. If not, you will wear your input shaft out.
Old 08-07-2007, 01:09 PM
MrDude_1's Avatar
it doesnt need anything special... i usually put some grease on it so the shaft so it slides in easier... dont put it on the outside (where it touches the crank) and dont put it an excessive amount on (grease + clutch = bad)
also, dont put any on the trans shaft.. you're bound to touch the clutch some, and if it gets on the splines, it will "scrape" into globs on it.. then be flung into the clutch (once more grease + clutch = bad)
just enough to rub onto the bushing is fine.. technically its soft enough that it is "self lubricating" as said previously.
Quick Reply: Lubricant for solid bronze pilot bushing?
