Car Died Out And Will Not Run!! Help!
Ok well today on the way to one of my buddies houses, i got on the gas up to about 4500rpms when all of a sudden a hear a semi loud bang..The car dies out almost immediatly and does not start again.....I had one of my neighbors come take a look at it and he said something about a oil sender?? I think thats what it was..If the oil sender went out would it cause the car to shut off and not be able to start up???..There was a little bit of oil on the ground where i finally stopped the car but nothing excessive..There were no signs of a knock or anything..The motor will still turn over and there are no strange noises coming from the engine bay...Oil pressure is @ 0 BTW..And the oil seems to only be on the passenger side of the car..Although no oil in the engine bay..Any thoughts guys???
~Drew D
~Drew D
LS1 Tech Administrator
Broken timing chain.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
You will get oil pressure with the motor just cranking. Pull your fuel pump fuse and try it some time.
__________________
Originally Posted by AutomagicLS1
Try to turn the motor over by hand you SHOULD be able to do it on your own. Pull some of your plugs out or all and see what you find. If you can get them all out try turning it over by hand it might give you an idea if somthing is seized up
Originally Posted by drewbster
The motor will turn over without a problem..Its not seized up..When i turn the key it will still turn over with no signs or noises of any problems..I called a few shops and they said that if an oil line or something of that nature broke then the motor would automatically be shut off my by the computer to avoid any serious problems??
Pull a valve cover off and turn it over by hand. Does the valvetrain move?
