Finished My D1 Setup Sunday!
I was going with a twin turbo setup and had to change due to shortage of money to finish the project. I found out that I had damaged engine parts that needed to be replaced. So I had to sell my Incon kit.
A guy on here really helped me out. he drove all the way to Kansas from Denver and traded Everything that I needed to rebuild my motor, and still go FI.
Anyways here is the setup.
ported 317 heads
comp 230/228 .591/.586 @ 114
typhoon Intake 85mm
Edlebrock headers
8rib D1sc, 3.4 blower pulley and 7.65 crank pulley
loudmouth exhaust
the twin intercoolers
speed density tune.
fuddle racing 3400 converter
i am going to try to get it tuned next week. This is on the 346 also. And here is the video of the start up
http://lucky.phpwebhosting.com/~fad2...s/MattsCar.mpg
ported 317 heads
typhoon Intake 85mm
Edlebrock headers
loudmouth exhaust
speed density tune.
what transmission you runnin?
4.5" coolers???
Look for psi loss after the intercoolers... i lost about 2-3psi with the smaller coolers... Just a thing to look for... I put a fmic on mine - ZERO psi loss...
4.5" coolers???
Fuel system is being upgraded as we speak. I have twin walbros in the tank with areomotive fuel regulator. I am trying to decide to run both tanks all the time or put the other on a hobbs switch. This will be on the 4l60e for now, I will change to a 400 once this one goes. I am not expecting it to last long. Just long enough to make a couple runs. Car only has 60,000 miles on it so I am hoping that helps a little.
As Bob said earlier the car should make some good boost, I do not mind if I lose a couple pounds after the coolers.
yeah see I had a turbo set up that I got rid of because I could not afford to rebuild the motor and finish the turbo setup. THis guy traded me everything that I needed to rebuild my motor and still go FI. That is why there is no front mount. When I get some extra money I might upgrade but I will do a tranny and a rear before then!
I hear ya on that one, I jsut bought a 9" and a chrome molly driveshaft as well as an external fuel system, before I get anything else it will be a trans. Thats the main reason why I want to start off with low boost. To break the motor in while I save for a trans. I would really like to save up and do the trans when I swap motors, etc. It would be ideal to do the FMIC then too, **** jsut keeps adding up, so I am trying to do this as smart as possible. Do as much as I can do all at once, I know I can't do absolutely everything but I think it will be a good start anyways. Good luck
