Installing CC503
dont forget about things like intake manifold gaskets, timing cover gasket, new timing set, a puller to remove crank hub, valve cover gaskets (although being rubber they can usually be reused) the possibility of needing new lifters, dont forget about leaving enough money to get the computer tuned, along with things that have already been listed
usually from what i've seen the majority of people produce peak power at around 5800 rpm
