Anyone selling a complete LT1?
I have a complete lt1 for sale, but its not low miles at all though 126k on it. ran fine when swapped for the 355 only problem i know if is the usual lt1 oil leaks, theres a pretty good one at the rear of the intake. otherwise its stock tb to oil pan afaik, i never even pulled a vc off. i'm also from IL where are you located. if you're interested i can send you some pics.
I have a Chad Golen 383 NA LT1 i would be willing to sell, it has about 5500 miles on the long block and under 1000 on the top end. Its the exact setup as his 480hp LT1 build up except i used 1.6 rocker arms instead of 1.5. The heads are stage 2 heads (190 intake runners, flow 265 cfm) 236/244 cam, 30lb svo injectors, ported LT1 intake, offer me a price and i would consider selling it to build an LS1.
