Spohn Torque Arm loosening?
Have the floor pan mounted torque arm... Has anyone had an issue with the nut/bolt on the joint where it mounts to the crossmember loosening?
Couldn't figure out where the heck this bumping was coming from until I had it in the air. Once I did, I noticed that I was able to twist the torque arm about half an inch. Tightened it down to the 50lb spec and it was good for all of a week.
Should I replace the lock nut? Just add Loc-Tite? Tack it in a couple areas? My car vibrates quite a bit so not sure if Loc-Tite red will even be enough. Opinions and has anyone else run into this?
Originally Posted by koji777
Loc tight it... haven't had any issues since....
Peeked underneath... looks like it's going to be tight to get even a combo wrench in there
