headlight problem
headlight problem
My 2000 Trans Am started making a real bad noise from the driver's side headlight. I popped the hood & its the motor that sits behind the light. It keeps running after I unlock the car with the transponder or turn the car off. Makes a real bad grinding sound. Anyone know why it is doing this?
Thanks,
Kevin
Thanks,
Kevin
LS1Tech Administrator
Received 1,488 Likes
^ Read above.
Some nice brass headlight gears should fix that problem.
Moving to General Maintenance & Repairs...
Copy & Paste Moderator
Just spreading the word as I just found out about these. HELP (motormite, Dorman) makes a replacement plastic headlight gear for about 15 bucks. Autozone can order them, but it may take a few days to get them in. Part # 42400.
https://www.dormanproducts.com/cgi-b...tegory_list=:0
