where to jack and place jack stands?
As the title says...Where is the best place to left the car with a jack and place the jack stands? Iam as worried that the weight will warp the body a little.... Pics would be great......
The jacking points will work just fine, just dont leave the car jacked in one corner for 2 days. I always do as already stated, the whole front, or the whole back is coming up when I work on mine. Jack it up at the axle, or the k-member.
sub frame, there are jacking points on all cars and usually on the pinch welds. then from there just place the jack stands on the k member or where ever is strong enough to support it, i usually use the big bolts on the k member to place the jack stands.
Originally Posted by Tram
Yeh, I think I'm going to use the K-member and the axle..
Yeh, I need to make sure I know exactly what the K-Member is.. I feel like the consumate newb saying that, but I just need to make sure I am putting the jacks on it..
It shouldn't have to sit up there long, maybe 2 weeks max..
Originally Posted by 1Loudz28
installuniversity has a good descriptive write up
71velle. If you have the engine/tranny out of it that will take a good bit of the stress off the front end. On the front frame rails it should be fine. But by far the best spot is the k member. I dont know what you plan on doin with the engine but if its possible Id bolt the kmember back up in there if the cars gonna be outta comission for a while.
well honestly i was planning up until January im doing full motor rebuild so im not positive depends on how long maching takes and how long parts take thanks for the advice on the k member idea ill probally do it if it keeps stress off the car
when jacking up one side to put jack stand under, will that make exterior body panels flex or bend, till i jack the other side up.
just not sure bc i dont trust having my front left 2 feet in the air
