Removed AIR today but need help.
Old 08-07-2007, 10:08 PM
JScamaro's Avatar
Default Removed AIR today but need help.
I decided to remove the AIR emissions today and everything went smooth except for the thing that needs plugged on the intake.
Can anyone give me a picture or describe what it looks like?
The only thing I saw was a little black plastic tubing coming from the back on the engine. Is this the right thing to plug? The black tube connects to this plastic connector that I removed with all the tubing.
http://img117.imageshack.us/img117/6...ture002oj6.jpg
Old 08-08-2007, 04:39 PM
sroach20's Avatar
the little black plastic tubing on the back of the engine is the piece you need to plug. it goes to a tee off the back of the manifold.
Old 08-08-2007, 05:16 PM
3.4camaro's Avatar
put some RTV in the tubing and you're good to go. Leaving that unplugged can cause misfires and bad running.
Old 08-08-2007, 05:21 PM
sroach20's Avatar
you could do like me and eliminate the hose. i ripped the t off the intake and got a coupler to run it over to the connector next to the computer.
Old 08-08-2007, 10:39 PM
JScamaro's Avatar
I saw a small rubber T fitting that I plugged with a screw but it was located near the back of the driver side fuel rail/cylinder head. After I plugged that one I still had an exhaust leak.
Is this the correct one or is it farther back directly behind the intake manifold?
The one I plugged looks just like the rubber fitting on the top of that plastic connector in my first post.
Old 12-09-2007, 02:25 AM
NemesisC5's Avatar
