Convertible Vehicles - Trap Door Mod
View Full Version : Trap Door Mod
WS6Drop
08-09-2007, 04:03 AM
Is there any way to do the trap door mod for the fuel pump on a vert? If so, where do you cut?
Irish350
08-10-2007, 02:17 PM
im not sure i know what you mean.. but as far as i know the fuel pump on verts is the same as other f-bodies..
...what is this trap door mod?
Shamson5.7
08-10-2007, 02:35 PM
He probably means installing a door for easy access to the fuel pump/gas tank.
MrDude_1
08-10-2007, 02:42 PM
its done the same way as on the coupes.
although i highly reccomend taking the time to do it right.. its only a 2 hour job start to finish.
WS6Drop
08-10-2007, 09:36 PM
Thanks, I know inside the car is a little different in the back. Just wanted to make sure.
Irish350
08-11-2007, 02:40 AM
do you really need to get at it that often? or is it just that much easier for one time things, like installing fuel pumps?
taner
07-12-2008, 08:42 PM
any one got pcs of where they cut theirs? i have been searching online but can find nothing! damnit!
cnorton
07-13-2008, 10:16 AM
E-mail coming your way with the article and picture w/dimensions.
c
O1ws6
07-13-2008, 11:34 AM
http://i254.photobucket.com/albums/hh96/tonymaiese/Picture069.jpg
2001 ta vert
simpleman
07-14-2008, 09:21 PM
You may not need to get to it all that often, but it sure as hell beats havin to drop the fuel tank. The carpet covers the patch work so no one knows unless you tell them. I dont have the measurements handy, but if you dont get them I'll post them.
00Camary
09-12-2008, 01:48 PM
One word... Fumes. Unless your exhaust exits out the rear.... just drop the tank.... run as much of the gas out as you can first obviously and its not so bad dropping the tank.... looks like that would take a lot of work cutting that hole. will probably be louder in the car too. ;)
98Bird
09-16-2008, 08:04 PM
I cut mine in my 'vert and it didn't take long at all with a rotary tool. Broke about 5-7 cutting disks.
With the hole, I put a wooden board over it (used to mount an amp) and then the carpet. You should at least put a board over it.
I didn't notice any extra noise nor any extra fumes at all (car is mostly stock).
gyrene2003
09-23-2008, 06:08 AM
post somr pics please
