brake piston
What I do is usually grab the brake pads you are replacing and use them along with a c clamp to push the piston back in. Either the pad will work or some piece of metal or wood. If you're doing dual pistons make sure you distribute the pressure equally so that the pistons don't get stuck or damaged.
Copy & Paste Moderator
