Car won't go above 4500rpm
Old 08-09-2007, 02:05 PM
ronald so's Avatar
Default Car won't go above 4500rpm
I just finished a swap into my nissan 240sx. And the car just goes flat above 4500 rpm. It feels like it hit redline. I tried another ecu (2002 ws6 motor last serials are 911 i believe)it pulls way harder but does about the same. It doesn't even spin 1st.
Any suggestions?
1998 240sx
2001 ls1/t56 from a ws6
both ecu are rear 02 elimate, vasts eliminate, egr eliminate, air pump turned off)
Old 08-10-2007, 10:17 AM
VinceTrifecta's Avatar
How is the fuel pressure?
Old 08-10-2007, 10:26 AM
Doc
Doc's Avatar
Were these pcm's tuned specifically for this application? Or were they tuned in person? Point being, has a crank position relearn been done? Which style VIN is in the pcm(s)? F, Y, etc?
